Display the MSDP Count
Use the following procedure to display the number of sources and groups sent and received.
  1. Enter Privileged EXEC mode:
    enable
  2. Display the MSDP count:
    show ip msdp count [vrf WORD<0-16>] [vrfids WORD<0-512>] [<0-65535>]
Switch:#enable
Switch:1#show ip msdp count
                          MSDP Count - GlobalRouter
SA state per peer Counters, <peer>: <# SA learned>
192.135.250.116: 24
144.228.240.253: 3964
172.17.253.19: 10
172.17.170.110: 11
SA state per ASN Counters, <asn>: <# SA-count>
Total entries: 4009
?: 192, 9: 1, 14: 107, 17: 5
18: 4, 25: 23, 26: 39, 27: 2
32: 19, 38: 2, 52: 4, 57: 1
68: 4, 73: 12, 81: 19, 87: 9
Variable definitions
The following table defines parameters for the show ip msdp count command.
Variable
Value
<0-65535>
Specifies the AS number.
vrf WORD<0–16>
Displays configuration information for a particular VRF.
vrfids WORD<0–512>
Displays configuration information for a particular VRF ID.
